I am using commerece for umbraco and this error to be come in admin section When I chose "Create" command for Order node in [commerce] - Umbraco
Server Error in '/' Application. ERROR CREATING CONTROL FOR NODETYPE: initorders Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ArgumentException: ERROR CREATING CONTROL FOR NODETYPE: initorders
Source Error:
Stack Trace:
[ArgumentException: ERROR CREATING CONTROL FOR NODETYPE: initorders] umbraco.cms.presentation.Create.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\presentation\umbraco\create.aspx.cs:45 System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14 System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35 System.Web.UI.Control.OnLoad(EventArgs e) +99 umbraco.BasePages.BasePage.OnLoad(EventArgs e) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\businesslogic\BasePages\BasePage.cs:287 System.Web.UI.Control.LoadRecursive() +50 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Version Information: Microsoft .NET Framework Version:2.0.50727.3053; ASP.NET Version:2.0.50727.3072
When I choose "Create" command for Order node in [commerce] - Umbraco CMS error was generated.
Hi all,
Source Error:
Stack Trace:
